Problem: linking to XDCAM folder - no files found
John Ahlbäck
on Sep 23, 2015 at 11:13:32 am
Hi
[The problem in short: can not link to folder with XDCAM .mp4. Linking to a file works.]
I am on a newly installed Media Composer 8.4.1 connected to an ISIS. I just downloaded the latest plugin at http://www.sonycreativesoftware.com/pdzk-ma2
Linking: When I select a file and "(*.mp4)" it works. When I select a folder and "(Folder)" - no clips are found.
- YES, I am selecting the folder above the BPAV.
- NO, there are no spaces or special characters in the folders path.
- IN FACT, I also have .mxf in different folders and linking to those works.
Also, why do I only see "Link" in my settings and not "AMA"? Did they change this?
I would greatly appreciate any help!
Shane Ross
Re: Problem: linking to XDCAM folder - no files found
on Sep 23, 2015 at 9:59:31 pm
[John Ahlbäck] "Also, why do I only see "Link" in my settings and not "AMA"? Did they change this?"
Yes, they changed the terminology to LINK. Same function, different name.
Shane
Little Frog Post
Glenn Sakatch
on Sep 24, 2015 at 4:12:20 pm
Try alt dragging the folder into an open bin in avid. You should get the little curved arrow icon before you release. This is another way of linking items in avid.
Glenn
