XAVC MC7 ama link/import problems
bj emery
on Sep 19, 2015 at 3:02:47 am
I have several MP4's that were shot on a Sony a7s.
XAVC/120fps
I have downloaded and installed the XAVC/XDCAM Plug-in for Avid (PDZK-MA2) v 3.41.
I am still unable to ama link to the footage, it just tells me it is unable to link.
I checked the console and it says that these are installed, I assume the second one is the one I recently installed because of the same version number.
MVP_MSP_SonyXDCAMEX_64bit Sony Corporation 1.9100
MVP_MSP_SonyXDCAM_64-bit Sony Corporation 3.4100
Is there anything I am missing? I am beating my head against a wall here, and would love to find an open window.
Massimo Alberto Croce
Re: XAVC MC7 ama link/import problems
on Sep 19, 2015 at 9:19:03 am
instead of auto-detect plug in in the link to ama dialog box, try to use Sony plug in.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Michael Phillips
on Sep 19, 2015 at 12:08:16 pm
If it is recorded using the XAVC-S codec, then it is not supported by the Sony AMA plug-ins. There has been lots of threads on this issue. For example: http://community.avid.com/forums/t/129982.aspx?PageIndex=1
You can use Resolve to transcode, ClipToolz to rewrap (PC), purchase an AMA plug-in from Drastic Technologies that supports it ($99), and some other workarounds that I may be missing but others can fill in with here.
Michael
bj emery
on Sep 19, 2015 at 4:45:28 pm
I tried that, thanks for the suggestion! It still didn't work though.
Michael Phillips
on Sep 19, 2015 at 5:07:27 pm
Which solution and what didn't work exactly?
Michael
bj emery
on Sep 20, 2015 at 8:51:10 am
I'm sorry. I tried selecting the sony plugin manually as Massimo suggested and it still didn't work.
I also have tried "wrap to MOV" in cliptoolz as I saw suggested in another thread, no dice.
I guess I will have to transcode through resolve.
