Animatte Tracking of Two Elements to Each Other?
Nina Lucia
on Sep 3, 2015 at 10:02:46 pm
I have two takes of the same shot (window in bg that needs to be replaced), both of which are moving around quite a bit. I need to take the window from one and put it into the other.
I have gotten the tracking for the cut out I made in animatte for the fg layer. Now I need to figure out how/if I can use tracking to get the window of the second element, the other take, to go into the cut out area of the fg shot.
Is there a way to do that? To track the bg shot with the fg shot?
Thanks.
Shane Ross
Re: Animatte Tracking of Two Elements to Each Other?
on Sep 3, 2015 at 11:27:44 pm
You'll find that Avid is a very poor compositing application. This is something best done in After Effects. Avid can be made to do a great many things. But what you are attempting...alas...isn't one of them.
Shane
Little Frog Post
Nina Lucia
on Sep 4, 2015 at 2:27:38 am
Thanks Shane!
Don't know After Effects yet so we'll see what I come up with. Maybe 567 key frames. :)
Alain Dessauvage
on Sep 6, 2015 at 12:27:38 pm
Not true Shane, Avid's compositing tools are quite good: tracking and stabilization, keyframeable garbage mattes with bezier splines etc.
What you need to do:
- put the background on V1 and the foreground on V2
- stabilize the foreground using the Region Stabilize filter. You should be able to completely lock the foreground element otherwise things will get difficult
- alt drag the 3D warp filter on V2 and the select the tracking module
- track the background using one or two tracking points. The second one is necessary if also tracking rotation or scaling
- enable the tracking and reposition the foreground element on the background
- crop your foreground element. If you need a more precise crop, alt drag the animatte filter and create a custom shape
- this shape can then be tracked as well, if necessary.
To my knowledge, Avid is the only NLE that enables this kind of composition work without leaving the software
http://www.imdb.com/name/nm0220918/
Nina Lucia
on Sep 15, 2015 at 8:11:04 pm
Thanks for the tip Alain.
One thing though, I do not want to stabilize the fg. That shot is good as is. Is there a way to do the shot without that step? Stabilize the bg then track it to the movement of the fg shot?
I have time to play around with it now so I'll try what you mentioned without stabilizing the fg and see what happens.
So I ended up manually keyframing the bg and for a 307 frame shot I have 59 keyframes. It jiggles a little bit but it's not too bad!
