problem importing mxf op-1a into Media Composer 8.0
Levan Birkadze
on Sep 2, 2015 at 8:36:59 am
I have Media Composer 8.0.0 installed
I try to import mxf op-1a video file (exported from Premiere pro) using AMA link and it fails.
I check the console and it says that the plugin is missing.
I downloaded plugin from Avid website (http://goo.gl/6fwv7), but the installation failed as it does not support Media Composer 8!
is there any solution to import mxf op-1a files into MC 8?
p.s. I am new to avid
thanks!
Massimo Alberto Croce
Re: problem importing mxf op-1a into Media Composer 8.0
on Sep 2, 2015 at 10:45:14 am
instead of auto-detect plug in in the link to ama dialog box, try to use MXF plug in.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Levan Birkadze
on Sep 2, 2015 at 10:48:59 am
Thanks! Thanks!
on Sep 2, 2015 at 10:51:08 am
you are welcome!!!
