Script Sync Take Order
Josh Stein
on Aug 13, 2015 at 7:20:54 pm
Script synced question:
When I drag multiple takes from a bin (usually only happens on scns with over 8 or so takes), they line up on the script in what seems to be a random order...
Any reason this would happen? The take column on the bin is correctly assigned to each take.
Michael Phillips
Re: Script Sync Take Order
on Aug 14, 2015 at 12:01:19 am
I'll have to look into this. So up to 7 takes, order is correct and after that it gets mixed up? Is that consistent?
Michael
Marian Jimenez
on Jun 7, 2017 at 4:30:19 pm
Im more interested to find out why when I add a clip a second time I can't get it to be in the right order, or move it to the right order.
for example I used to put all the takes of a set up Take 1-5 on the script and if I found a reset I would just add take 2 again for example and it would sort next to the other take 2 clip and I didn't have to delete take 3-5 in order to make the second clip of take 2 to be next to the first clip of take 2.
Not sure if I'm explaining myself well.. let me know if you have any solution.
Marian
Aren Hansen
on Mar 30, 2018 at 6:01:57 pm
Hey,
I'm struggling with this too. Did you find a solution/workaround?
