Avid MC 8 jittery playback issues with MacPro OS 10.10.3
Maria Wardian
on Jul 22, 2015 at 9:54:39 pm
In editing a short form project in Avid MC 8.4, we are getting a jittery and skippy video playback consistently even though we're watching at half res (green/yellow), rendering fully and often with no color bars on timeline, using a powerful MacPro, and have only one editor working off this media partition on our Facilis server. For client viewing, we are connected to a Panasonic TV through an AJA ioXT. It seems to get bad enough for a need to restart the whole computer, which helps for a short while. Any tips on how to optimize our set up and avoid so many restarts?
More details on the setup:
MacPro cylinder (Late 2013OProcessor: 3.5 GHz 6-core32 GB ramGraphics: AMC FirePro D700OS: 10.10.3Avid MC 8.4. Project is 1080p 23.98, RGB 107.
Media: We ingested DNxHD encoded QTs and some ProRes4444 to a 1920x1080 23.98 project DNxHD 36 mxf. Avid media is on it's own a separate partition from the project, all only being used by one editor at a time with plenty of space.
Server: Facilis version 6.2, restarted 1-2 times/week, connected out via ethernet.
Monitor out to Panasonic LCD TV through AJA IoXT HDMI out.
AJA with latest software and driver (install 12.2.1).
AJA Format matches Avid sequence: 1920x1080 23.98, color space YUV 8 bit
*It helps to disconnect the AJA for monitoring, but doesn't completely solve.
Edit: It's short! 30 second commercials, some simple masking and scale/position keyframes.
Thanks for any input!
Maria W
Bob Zelin
Re: Avid MC 8 jittery playback issues with MacPro OS 10.10.3
on Aug 1, 2015 at 5:52:56 pm
are you getting jittery playback just on the AJA I/O XT output and Panasonic TV, or is it also jittery on the Mac computer screen when it plays back ?
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
Joe Morris
on Oct 11, 2015 at 4:22:14 am
I've been having the same issue on 8.3 onwards to 8.4.1.
I have found if I "downgrade" and resinstall 8.1.0, it fixes the issue.
Its very annoying.
When 8.0 was released I had the same issue, 8.1 is the only release that the playback issue doesn't occur with (apart from 7).
Film Editor & VFX Supervisor
http://www.joejmorris.com
http://www.freelancefilmeditors.com
