Progressive footage to interlace
Cláudio Teixeira
on Jun 24, 2015 at 7:31:13 pm
Working with Avid Media Composer 8.2.0 on a project 1080 / 50i with interlaced material.
Received material recorded in blackmagic in progressive and what happens is an image rate .
What can I do to pass the progressive interlaced material ?
Shane Ross
Re: Progressive footage to interlace
on Jun 24, 2015 at 9:23:36 pm
[Cláudio Teixeira] "and what happens is an image rate"
Sorry, can you explain that better, please? What is "an image rate?" What is the frame rate of the footage shot? 25p or 50p?
[Cláudio Teixeira] "What can I do to pass the progressive interlaced material ?"
Just cut it into the sequence. There's no way to interlace progressive footage of the same frame rate. Hmmm...but if shot 50p, can you make that smoother 50i, instead of it being 25 progressive frames...hmmmm
Shane
Little Frog Post
Cláudio Teixeira
on Jun 24, 2015 at 9:29:45 pm
Recorded material 50i and another 25p . The project was open to 1080 / 50i .
When using material recorded at 25p have image press.
What to do to solve this?
