QT file came out too large
Avi Lev
on Jun 10, 2015 at 9:44:31 pm
I'm using Avid MC 5.0.4 on MAC v10.6.8
I exported 1 hour doc to QT file on MPEG 4 Video. 1440 x 1080.
The good new is that it comes out as perfect resolution, but the bad news that it is a large as 30GB.(?)
What should I do to make it smaller, yet, keep the size as is?
Thanks, Avi
Shane Ross
Re: QT file came out too large
on Jun 11, 2015 at 6:55:06 am
Export for what? Meaning...what's the intent for this export? Web? Broadcast? BluRay?
1440x1080 is anamorphic HD...HDV generally, some flavors of AVCHD. You really want a full raster 1920x1080 export. But again...export for what?
Shane
Little Frog Post
Avi Lev
on Jun 11, 2015 at 12:12:04 pm
Thanks Shane
I would like to screen the doc in lecture rooms. That's why in need the highest resolution QT file.
The scenes in the doc were shot on HDV 1440x1080.
I guess at that point it will be too late to change the raster Dimension on the project's format.
But, I still want to understand how it possible to shrink the size of the exported file?
William Busby
on Jun 12, 2015 at 12:09:33 am
the bit rate basically determines file size. For 1 hr you probably had it set for 50+ Mbit bit rate or something close. I haven't used Avid to export anything other than QT Ref files and prefer to use AME, Rhoset or Sorenson for encoding purposes. Lower the bit rate considerably (like 8 Mbit or so) and it should still look more than presentable.
Avi Lev
on Jun 14, 2015 at 3:27:42 pm
Thank you William.
Here is the deal:
Dimension: 720x480, Duration: 54:55 Codecs:MPEG4 Total bit rate:7,038
Dimension: " Duration: " Codecs:H264 Total bit rate:5,831
Dimension: 1440X1080 Duration: " Codecs:MPEG4 Total bit rate :83,252
Just by enlarging the dimension by approx 3 times the bit rate expends by almost 10 times.(?)
Is there any other way to export high resolution files with less pain?
Thanks,Avi
William Busby
on Jun 14, 2015 at 6:58:17 pm
How are you presenting this anyway? From a DVD? Blu-Ray? A mp4 file to be played from a laptop etc?
If a playable DVD you're basically stuck with 720x480 to stay within DVD spec, but set a 16x9 flag so it displays properly. Set the video bit rate at 8000 kbs, audio at 192 kbps.
If Blu-Ray, set video bit rate to 25000 kbs. If mp4/h.264 file from a computer's hard drive, set the video bit rate from 8000-10000 kbs.
What reason are you so concerned with the file size? What encoder are you using? This doesn't have to be complicated.
