Can't relink after transcoding to different drive
dan crouch
on May 27, 2015 at 9:07:49 pm
Hi guys,
Please can anyone help with this?
I have just transcoded some AMA clips from one drive onto a new drive that I need to take away to work from.
I have transcoded all the clips, turned off the original drive leaving my new drive on.
The new transcoded clips are all online, but the synch pull sequnecs that were made, obviously from the AMA's, are all offline.
When I match frame the clips in the offline sequence, they go back to the AMA bins and not my new transcoded clips.
Any help would be very much appreciated.
Dan.
Michael Phillips
Re: Can't relink after transcoding to different drive
on May 27, 2015 at 9:33:28 pm
Highlight the sequence and do a relink to see if it finds anything. If not, highlight all the .new clips from the transcode and do a right-click on sequence/relink then select "relink to selected" and see what happens.
Michael
