Same Audio Goes Offline At Launch
Bob Zerweck
on May 27, 2015 at 6:35:52 pm
I've been working on a feature as an assistant editor for several months right now but lately we've been having an issue on multiple computers that I can't seem to figure out.
For some reason, one of our shots, the same one, goes offline every time the project is opened up, just the audio. I relink the shot easily, work as normal, but the next time the program launches the file is offline again. I have tried rebuilding the databases to no avail. Has anyone experienced anything similar like this?
AVID: 8.3.1
Project: 23.976 1080p, working with 115 DnxHD files.
Computer: OSX 10.9.5
Thank you guys for your help.
Michael Phillips
Re: Same Audio Goes Offline At Launch
on May 27, 2015 at 7:05:30 pm
How was the clip created in the first place? And was it done via an ALE import and link to media?
Michael
Bob Zerweck
on May 27, 2015 at 7:09:52 pm
Thanks for the response,
It was transcoded in Redcine X, dnxhd 115. I imported the resulting ALE after copying over the mxf files into Avid Mediafiles.
Michael Phillips
on May 27, 2015 at 7:17:24 pm
I never recommend just using the ALE form a third party transcode to relink to media as I always hear about unlinking such as this. The preferred and recommended method is to first import the AAF files also generated by Redcine X Pro, then merge the ALE into the master clips for the additional metadata. AAF caries the parent/child relationship and directly links to the MOB ID's in the mediafiles that is not available by ALE alone.
A lot of this is covered here, and there is a rather detailed RED section:
http://www.avid.com/static/resources/documents/whitepapers/digital_camera/d...
Michael
