Need to export Prores444 UHD wt 8 audio channels
Chris Coote
on May 19, 2015 at 3:58:59 pm
Hi
I am working at 3840x2160 in Avid. I need to deliver Prores444 with 8 discreet audio channels.
As far as I know, I can't do this directly out of Avid? In testing, my workaround is export same as source
to DNXHRX with 8 discreet channels and then open the file in QT - re-export to Prores444.
Is this the best/only way to do this?
Chris
Massimo Alberto Croce
Re: Need to export Prores444 UHD wt 8 audio channels
on May 19, 2015 at 8:21:05 pm
Why don't do directly from avid?
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Chris Coote
on May 19, 2015 at 8:31:02 pm
Direct out is greyed out in the audio settings unless you do a same as source or reference movie.
You can't do a mixdown to prores in the avid in UHD resolution, only in HD.
Unless there is some other way I am missing?...
John Pale
on May 23, 2015 at 3:25:43 pm
Not in front of a system to test, but if you switch the color space to RGB, does ProRes become a media creation option in a UHD project?
