change import setting for clip afterwords ?
cj bravo
on May 19, 2015 at 7:50:35 am
hey, newbie to avid, after finishing my editing i've noticed that my clips arent in the setting they should be- i imported them as DV 411 in a 25P project instead of a 1080p/25 and import as DNxHD 36...
Is there anything i can do without creating a new project and re-edit everything ??
thanks,
CJB
Shane Ross
Re: change import setting for clip afterwords ?
on May 20, 2015 at 7:53:34 pm
At this point, why does it matter? You are doing an offline cut..both are offline codecs. Just online properly when done.
I offline at DV25 on many many shows...looks fine for an offline.
Shane
Little Frog Post
