Copy and past column data to another column
Scott Davis
on May 8, 2015 at 3:16:27 pm
I was shown at one point how to copy an entire column's data to another column. For the life of me I can not remember how to do it. Any ideas?
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Hancock
Re: Copy and past column data to another column
on May 8, 2015 at 3:29:10 pm
Select the column header , hit Cmd/Ctrl+D, pick the column you want to copy it to and hit OK.
Michael Hancock
Editor
Scott Davis
on May 8, 2015 at 8:10:57 pm
Michael, thanks. It doesn't seem to be working. I am on 8.3.1 if that maters. What is "ok" mean.
Scott Davis
Michael Phillips
on May 8, 2015 at 11:26:22 pm
What part is not working? The entire column will highlight, then do a command-D or control-D and a dialog box pops up with a list of columns. Select, click OK. Not all columns are equal, an obvious one is copying comments to a timecode column for example.
Michael
Scott Davis
on May 9, 2015 at 1:26:47 pm
Michael, The part that is not working is the guy behind the keyboard. I was hitting "control" and "command" and "D" and nothing was happening. When I hit just"command" and "D" it works perfectly. Thanks so much.
Scott Davis
