Shortcut for 'go to next clip' in Source / Record monitor?
Brad Kimbrough
on May 7, 2015 at 7:42:08 pm
I'm drawing a blank here. Is there a keyboard shortcut to 'go to the next clip' in the Source / Record monitor? As in, I have 2+ clips / sequences loaded and want to toggle between them, within the 'Clip Name Menu'.
(This is different, of course, from the Esc key, which just toggles between the Source / Record sides.)
Thank you!
Brad
Shane Ross
Re: Shortcut for 'go to next clip' in Source / Record monitor?
on May 7, 2015 at 9:12:22 pm
The name of that is FAST FORWARD, and REWIND. And you can map them to wherever you want to. I put them on the UP and DOWN arrows, like they are in FCP 7.
Then, in the COMPOSER SETTINGS, in the FF/RW tab, you can have it ignore track selectors, stop at head frames...and the like.
Shane
Little Frog Post
