consolidating issues
Cesar Mendonca
on May 5, 2015 at 7:46:07 pm
Hi guys!
Im trying to consolidate a sequence into a hard disk and i have no success with it.
I manage to consolidate it into the internal drive however.
I reckon that I have a problem with my drives but I don't know how to fix them.
It appears among my drives when I'm preparing to consolidate. I can select it and order consolidating.
But as the process starts AVID starts loading file informations and then says
Any suggestions?
Thanx for the help!
cesar
MEndonca
Andrew Kimery
Re: consolidating issues
on May 5, 2015 at 10:40:47 pm
Do you have write access to the hard drive you are trying to consolidate to?
Cesar Mendonca
on May 6, 2015 at 11:07:39 am
I do. Actually the problem goes deeper that this.
Someone told me today that maybe the problem was that I was building the Avid MediaFile folder on my own and that I should let the computer do it.
I just tried to do it: got a totally empty disk without any files on it; compressed on ExFat and with R/W permission and opened Avid. I went to Media Creation and just like before the only drive the program shows me is the internal drive of the computer.
Any suggestions on what should I do to fix this?
MEndonca
Ricky Barrow
on May 6, 2015 at 1:08:59 pm
If you built on your own, make sure you name correctly: Avid MediaFiles\MXF\1
ExFat works for us in RW but I haven't actually tried to consolidate to it.
Ricky
John Pale
on May 7, 2015 at 12:27:24 pm
Yeah. Normal read and write ...never had a problem, but I have had consolidating issues. It was awhile ago, the last I attempted it.
John Pale
on May 6, 2015 at 12:34:44 pm
Try NTFS or Mac OS Extended. Not sure you can Consilidate to ExFat. I remember running into this in the past.
