Relink transcoded media back to original fotage (via AMA)
david choen
on May 2, 2015 at 8:24:47 pm
i have a project that was shot with canon 7D
i linked to ama the fotage -> transcode it
then i created a new sequence and edited the transcoded media
now i want to relink all the media in the sequence bake to the original camera fotage
and to get a new sequence with only ama links as time line media.
i cant find a way to do so...
i need my sequence to be all link to ama for AAF export
(when MXF files are exported as AAF the post prodaction softwere cant read from the AAF the MXF becuse MXF does not suported by this softwere, whene link to AMA is exported as AAF the softwere read from the original camera fotage)
Glenn Sakatch
Re: Relink transcoded media back to original fotage (via AMA)
on May 3, 2015 at 3:50:26 pm
There are several posts in this forum that explain the process.
as a quick review:
make a bin, and put your ama links in that bin
select all the clips in that bin
right click on your sequence and select relink
you are looking for the option to relink to all selected clips in open bins. You may have to play with some of the other settings after that to get the relink to work.
Glenn
