Best Mac to run Avid Composer on
sarah lauch
on Apr 16, 2015 at 6:23:36 pm
Hi. I am about to build out my own personal Avid. I would like dual monitors and will use a Mac. Anyone know the easiest way to do this and what Avid is best? Would it be best to have a tech come and build it out? I do have experience with all this technology. THANKS!
Shane Ross
Re: Best Mac to run Avid Composer on
on Apr 16, 2015 at 8:24:05 pm
BEST? Well, the new MacPro tube will, as will the MacBook Pros...all the iMacs...MacMinis will. Not sure the new MacBook can...it's processor is a mobile one (used in iphones). MacBook Air would barely cut it. So...the question is, what's your budget?
And you really only need a tech if you are going beyond simply installing the software onto a computer. If you want to add HDTV or broadcast monitor, you'll need an IO device...either Avid or third party. And that'll take a tech to set up, if you aren't technically inclined.
Shane
Little Frog Post
sarah lauch
on Apr 16, 2015 at 8:31:07 pm
AWESOME! thank you Shane!
