Annoyance: Match frame without pushing alt
Benjamin Steiner
on Apr 9, 2015 at 11:42:14 pm
I have chosen Y for "match frame", but match frame by default destroys the Mark In. If you push Alt with it, it leaves the Mark In unchanged.
I would like Y to actually do Alt+Y "match frame without changing mark in".
Is that possible?
Shane Ross
Re: Annoyance: Match frame without pushing alt
on Apr 9, 2015 at 11:58:13 pm
Go into the COMMAND PALETTE, choose the OTHER tab. Now also map the OPTION key to the Y key...then it should do what you want. I do this with the C command. I don't just want what I selected put in the clipboard, but I want it immediately put into the PREVIEW monitor. To do that you press ALT/OPTION-C. But I mapped OPT to C as well and now it does it with one push of the button.
Shane
Little Frog Post
Benjamin Steiner
on Apr 10, 2015 at 12:19:38 am
thanks, that's great news, didn't see this "add alt key" button in Other. But it doesn't work for me (I am on PC), when I drag the Add Alt button to Y it doesn't do anything...
