Auto Sync, Missing Waveform
Ben Northenor
on Apr 3, 2015 at 5:03:18 pm
I'm auto syncing some audio to picture, but when it syncs, I can't find the waveforms. They just disappear. Any help/info would be great! Thank you in advance.
http://www.bennorthenor.com
Michael Phillips
Re: Auto Sync, Missing Waveform
on Apr 3, 2015 at 5:08:35 pm
Are you saying you can't see the waveforms on the newly created .sync clips? In the source monitor or record monitor? What version and OS?
Michael
Ben Northenor
on Apr 3, 2015 at 5:27:22 pm
Correct. I can't see the waveform in the newly .sync clip in my Record Monitor. I'm on version 6.5.4.4 and the OS is 10.8.5
Michael Phillips
on Apr 3, 2015 at 7:16:02 pm
Can you see them in the source monitor when switching the timeline view to source monitor and enabling waveforms there? And can you see them on the original source files before syncing them?
Ben Northenor
on Apr 3, 2015 at 7:19:12 pm
I can on both. I exported the AIFF file to a .wav file from iTunes, but that still didn't help. I'm very confused.
Michael Phillips
on Apr 3, 2015 at 9:26:57 pm
Does the sample rate and bit depth differ from the project setting by chance? It does seem strange that you can see it on the clip before syncing. You might need to clear the waveform cache and see of that clears it up for you after it rebuilds.
In the project folder, there is a folder called WaveformCache. Delete its contents. Relaunch and wait a bit while they rebuild and see if that fixes it.
Michael
Ben Northenor
on Apr 3, 2015 at 9:51:58 pm
I can't find any WaveformCache files in my project file.
Michael Phillips
on Apr 3, 2015 at 10:08:51 pm
Right... cached waveforms was part of the 7.x release. I'm stumped at this point.
Michael
Ben Northenor
on Apr 4, 2015 at 12:51:47 am
I feel the same way. Thanks for trying.
