MC 8.3.1 viewer color
Oliver Peters
on Mar 31, 2015 at 1:23:17 am
In case you haven’t noticed it yet, you can change the viewer setting to other color spaces, including Rec709 full swing. Right-click in the viewer for the pulldown. If you use full-screen mode, you can do the same in the prefs set-up for the full-screen monitor. No more washed out look.
- Oliver
Orlando, FL
http://www.oliverpeters.com
