Sequence Editing using AMA's and re-linking to DNx175s
Ashish Sharma
on Mar 1, 2015 at 1:37:06 am
Hello,
A little new to Avid and still getting a grip on everything.
I currently have a sequence that was editing using AMA files and I would like to replace the AMA's w/ DNx175 files that I have encoded. I'm hoping that I can just right click on the AMA edited sequence in the bin and re-link to the DNx files, but wanted to get some advice since I'm still new to Avid.
Im using Media Composer 8 on Yosemite.
Thank You!
Michael Phillips
Re: Sequence Editing using AMA's and re-linking to DNx175s
on Mar 1, 2015 at 3:51:19 pm
The first thing to try is right-clicking your sequence, and select "Relink". Towards the bottom of the overly complex dialog box, there is a selection by which you can select a target resolution, in your case 175. See if that does the trick, if not, then we can move on to the next method.
Michael
