Some subtitles get lost when exporting!
Gerrit Stollbrock
on Feb 22, 2015 at 6:16:24 am
I would appreciate any hint regarding why three subtitles of a sequence get lost when exporting the project! All the other subtitles on the same track are visible, apart from these three. I have tried to duplicate them in a new track, change the whole subtitles track to a new one, exporting in different formats (H.264, DNx), etc.
I am quite new in Avid subtitling.
Emilia Mello
Re: Some subtitles get lost when exporting!
on Mar 13, 2015 at 11:44:58 pm
I am having the same problem. Were you able to resolve the issue?
Gerrit Stollbrock
on Mar 14, 2015 at 4:39:04 am
Hi Emilia, thanks for asking. After trying different Ways out, the only one that finally worked was to export the subtitules, to duplicare the sequence without the subtitles and import the subtitles back into the new sequence. Give it a try and let me know if it it worked for you. Good luck!
Emilia Mello
on Mar 14, 2015 at 10:48:55 pm
How did you export the subs and then how did you import the subs?
