AVID slow to respond / stuttering
Lewis Snow
on Feb 18, 2015 at 10:28:56 am
Hi All
Has anyone run across this problem before. I'm working in a project with relatively few bins, little effects and a couple of 60" timelines.
Opening or closing a bin, gives me a pinwheel for 5/6 seconds before it responds. Same thing when scrubbing through the timeline or hitting space to playback.
I've not tried much to fix it yet so we can start from the very beginning.
Running AVID 6.4, on:
Model Name: Mac Pro
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.26 GHz
Number of Processors: 2
Total Number of Cores: 8
L2 Cache (per Core): 256 KB
L3 Cache (per Processor): 8 MB
Memory: 12 GB
Processor Interconnect Speed: 5.86 GT/s
Glenn Sakatch
Re: AVID slow to respond / stuttering
on Feb 18, 2015 at 3:35:34 pm
Is this a new system for you, or do you do this all the time, and today it decided not to work?
If it is having trouble playing your footage, some info about your footage may be helpful.
What is your drive configuration, footage type, project type, compression you are working at.
(sounds like your drives can't keep up with what you are asking them to do)
Glenn
Lewis Snow
on Feb 18, 2015 at 5:58:33 pm
I'm pretty new to the company, this is a relatively old project.
Poking around though I think you might be right. They've been off lining at DNX120 through a G-Speed 16tb using a F/W 800 cable.
