Importing AE file with Alpha Channel into Avid 6
yvonne valdez
on Feb 11, 2015 at 8:31:57 pm
I have been trying to import an AE (CS5) DNX36 with Alpha to avid and I keep getting the error message-- Exception: Cannot quick import a mixed resolution QT movie --- I have tried Animation and TIFF as well.
Export settings out of AE are as follows.
Format: QT movie
Post Render: None
Channels: Alpha
Depth: Millions of Colors
Color: Straight (unmatted)
DNXHD codec: 23.976 dnx36 8 bit
When I import into avid I invert. What might I be missing?
Regards
YV
Glenn Sakatch
Re: Importing AE file with Alpha Channel into Avid 6
on Feb 12, 2015 at 4:01:54 pm
First thing to try...you need to select RGB+Alpha and Millions + as your setting. If AE only gives you either RGB or Alpha as an option, then the codec you have chosen doesn't support alpha channels. (not all codecs can embed alpha channels)
Try with Animation and the above settings.
Glenn
