AVC-I 100 format capture via KONA 3 G is not happening in AVID Media Composer
Sebastine Anand
on Feb 8, 2015 at 2:40:42 pm
I'm trying to capture AVC-I 100 format in AVID Media Composer using KONA 3G over SDI in Mac Pro, but not able to capture.
Can any one advise...
Regards..
Anand
Shane Ross
Re: AVC-I 100 format capture via KONA 3 G is not happening in AVID Media Composer
on Feb 8, 2015 at 5:26:49 pm
What are you capturing from?
Shane
Little Frog Post
Sebastine Anand
on Feb 10, 2015 at 11:45:23 am
Hi Shane,
This is to inform you that AJA confirmed, there are no plans to support AVC100 capture. Only playback is supported.
It is also possible to capture Pro Res or DNxHD; edit with a AVC100 sequence preset; export as AVC100 when project is complete.
Thanks for your support..
Regards
