How to link 4k .r3d files / Composer 8.3
Sabri Liefert
on Jan 27, 2015 at 1:02:05 pm
Hello,
what is the best way to relink files to an imported aaf sequence?
The aaf is made on an other composer installation.
The edit was made on a HD timeline with proxys.
Now i want to reconnect the timeline in Composer 8.3 to the original 4K Red .r3d files.
I tried to import the source files with ama. But they don´t connect?
Michael Phillips
Re: How to link 4k .r3d files / Composer 8.3
on Jan 27, 2015 at 5:41:34 pm
See pages 24-25 for starters:
http://www.avid.com/static/resources/documents/whitepapers/digital_camera/d...
Let us know if you are still having issues.
Michael
Mark Panik
on Jan 28, 2015 at 3:43:26 pm
Thanks for posting this :-)
Mark
http://dontpanik.tv
https://www.facebook.tv/DontPanikTV
http://socialyze.media
Sabri Liefert
on Jan 28, 2015 at 9:29:30 pm
Still don´t relink.
Isn´t there a more or less easy way to do it.
This should be a simple process?
Michael Phillips
on Jan 29, 2015 at 12:42:06 am
It can be easy, but one needs to know how the proxies were made for the offline - meaning the R3D file can be referenced by an embedded REEL which is only 8 characters, or is it the entire 16 characters? AMA uses the entire 16 original file name, and if a spanned file, will also include the _001 (which is stupid, but that's the way it works).
So, look at one of the offline proxy clips and bring up both the TAPE and SOURCE FILE column and see where the R3D file name lives, and whether it is 8, 16, or more. Then we can take it from there and set up the relink options.
Michael
Sabri Liefert
on Feb 3, 2015 at 3:12:40 pm
Thank you Michael for your reply!
For Example
the Filename in the imported aaf bin is:
a013_c015_1006rx
the file structure on disc is:
Folder:
ProjectX > Day 1 Card 20 > A013_1006JD.RDM
File:
A013_C015_1006RX_001.R3D
A013_C015_1006RX_002.R3D
The person who generated the aaf used 720p dnxhd proxies (see screenshot)
I want to relink to the original .r3d files via ama.
Michael Phillips
on Feb 3, 2015 at 9:18:53 pm
Assuming the timecodes are counting at the same rate (720 can count at 30 as well with frames pulled out to be 24)...
In the relink dialogue box when setting up, you need to check the "ignore extension" as well as enter "_" in the "ignore characters after last occurrence". See here:
Michael
Sabri Liefert
on Feb 8, 2015 at 5:48:55 pm
Thank you very much Michael!
The underscore does the trick!
Unfortunately i just ran into the next relinking problem.
I made some DNxHR UHD MXF files in Davinci Resolve,
which i want to relink to the editors timeline.
I opened the media tool and found the clips, dragged them into a new bin in the project.
Clips are in the folder c:/Avid Mediafiles/MXF/1
(i had to select "all projects" in media tool to find the files?)
I tried several relink options.
Is there a problem with the duration? File type?
I am at my wit's end.
Michael Phillips
on Feb 8, 2015 at 5:55:21 pm
If you don't have the full span of media available, then relinking it will not happen. Tape names seems to be fine. Did you render with handles in Resolve?
Michael
Sabri Liefert
on Feb 8, 2015 at 6:37:09 pm
No, i didn´t rendered frame handles.
Sabri Liefert
on Feb 10, 2015 at 11:46:12 am
The rendered files are shorter. Only the length of the edit.
What is the workflow to get them back from Resolve to MC?
Michael Phillips
on Feb 10, 2015 at 4:39:57 pm
That should be fine - Source ID seems correct in both instances - Did you play around with the "relink to selected" options as well to see what combination works?
felix martiz
on Feb 17, 2016 at 1:18:50 am
Hi there, I am truly having a heck of a time trying to relink my dmx files back to my 6k raw on Avid. I can really use your help because I am all out of ideas.
I got as far as the program relinking half of the files on the timeline only, not sure why this happened. Any help would be greatly appreciated.
thanks,
Felix
Michael Phillips
on Feb 17, 2016 at 1:56:26 am
Need more info as per above - screenshots of master clips with Tape and Source File columns showing, and what is expected by the timeline. Are the the same name, different column?
Michael
felix martiz
on Feb 17, 2016 at 2:56:11 am
Hello, thank you for your quick reply. In one folder I had the AMA link files, which i then transcoded to dmx files so that I can edit it on my slow computer at school. Now that I have a picture lock I want to relink the dmx files to the AMA Link files so that I can transfer the relinked timeline for grading. Any help would be very appreciated, thank you. below is the screenshot of the folder where I have both files, one ama link and the dmx file. The other folder is the relinked folder which has some files that relinked while others, like the one chosen, in limbo.
