Difficulty importing files
Phillip Byrd
on Jan 15, 2015 at 5:37:43 pm
I have been sent a hard drive with files I need for a project. They are .mxf files and are placed in the correct MXF/1 directory. Media Composer (7) appears to scan the files when booting. But when I open media tool, the files can't be located on the disc, so can't be imported to the project. I follow the drill of selecting source and destination in media tool, then closing media tool. Then opening again. And still can't find the files. As a check I was able to see other .mxf files on other drives with media tool.
Might this be media from MC8? Or is there something else I'm missing?
Ricky Barrow
Re: Difficulty importing files
on Jan 15, 2015 at 7:16:47 pm
Perhaps they are OP-1A MXF Files? If so, they need to be converted into OP-Atom files(Native to Avid).
Ricky
Michael Phillips
on Jan 15, 2015 at 7:54:28 pm
If they are OP-1A, then you should be able to AMA link to them using the AMA plug-in. If that is indeed the case, I would move them out of the Avid MediaFiles folder structure.
Michael
Shane Ross
on Jan 16, 2015 at 1:23:26 am
Locate the .mdb file in the MXF>1 folder. Drag that into a bin. It should populate that bin with all the media in that folder
Shane
Little Frog Post
