Migrating projects back and forth between AVID 7 AND AVID 8
Jake Frader
on Jan 15, 2015 at 3:15:11 pm
Does anyone know if I can go back and forth from Avid 7 and 8 (Open a project in Avid 8, then the next day open a project in Avid 7, and vice versa?). Will the project files remain intact?
Any help would be greatly appreciated!
Thank you!
Shane Ross
Re: Migrating projects back and forth between AVID 7 AND AVID 8
on Jan 16, 2015 at 1:24:31 am
Everything will be fine. However, whatever features you use that are MC 8 only, that MC7 doesn't have...won't transfer back. Such as deactivating clips in the timeline...4K media support...stuff like that.
Shane
Little Frog Post
Pat Horridge
on Jan 16, 2015 at 9:04:42 am
You need to have the latest point release for V7 which is 7.0.4.2
Also easier and safer to not swop projects just bins and media.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Jake Frader
on Jan 17, 2015 at 7:11:23 pm
Thank you both for your help! It is quite appreciated!
Mike Scannel
on Aug 24, 2015 at 6:23:49 pm
Does it have to be 7.0.4.2 or is 7.0.4 good enough?
Shane Ross
on Aug 24, 2015 at 6:30:45 pm
It's the last .2 that makes this possible. It's a free update...
Shane
Little Frog Post
Mike Scannel
on Aug 24, 2015 at 6:51:31 pm
Cool. Thanks. I am assuming the 7.0.4.4 update will do the trick as well. Do you have any idea if the 7.0.4.4 update supports projects created in MC8 on PC to migrate back and forth from MC 7.0.4.4 on Mac?
Desireena Almoradie
on Feb 22, 2015 at 10:57:05 pm
will i be able to migrate back and forth between 6.5 and 8 just as easily? or does this only work for versions 7 and 8?
Thanks for your help
Shane Ross
on Feb 23, 2015 at 2:15:47 am
Bin and project wise, yes. But many new features found in MC8 won't be in MC6.5.
Shane
Little Frog Post
Shane Ross
on Aug 24, 2015 at 7:04:38 pm
Sorry..., I meant .4.
http://avid.force.com/pkb/articles/en_US/FAQ/Media-Composer-8-FAQ#General%2...
Q: Is the Media Composer | Software (v8) license backwards compatible to Media Composer v7 or earlier?
A: We have released Media Composer 7.0.4 and Media Composer 6.5.4.2 that will run on a Media Composer | Software (v8) perpetual software or dongle license. They will not, however, run using a Subscription or Floating license. Please refer to this Knowledgebase article for more information.
Shane
Little Frog Post
Shane Ross
on Aug 24, 2015 at 7:07:37 pm
You need the latest patches in order to do this....basically.
Shane
Little Frog Post
