Avid AMA sequence to Premiere Pro is blank
Jean-Daniel Lagant
on Jan 5, 2015 at 10:29:34 am
Hi everyone,
I'm trying to import an AAF file from an Avid sequence with both AMA linked files et DNX-HD but all the AMA linked clips leave a blank space in Premiere Pro CC.
I tried to go through Resolve, FCP, but nothing worked.
I didn't find any efficient workaround on Avid, Adobe or CreativeCow forums.
Any idea ?
Thank you.
_______________________________________
One day I'll save the world...Promised.
Michael Phillips
Re: Avid AMA sequence to Premiere Pro is blank
on Jan 5, 2015 at 2:38:13 pm
I don't know if a workaround is available if PPro does not support AMA links defined in the AAF to the camera originals. In Resolve, I add all the camera originals to the MediaPool, then conform to camera originals. You might be able to then generate a new XML or AAF from there that now points to the camera originals. But note that generating a new AAF can be lossy for items it may not understand. Does Premiere allow you to relink to a directory for items in their project?
Michael
Glenn Sakatch
on Jan 6, 2015 at 2:56:06 pm
is the frame rate the same in both projects? I seem to recall FCP adding black inbetween clips if it was importing a59.94 sequence into a 23.98 timeline.
Glenn
