Export single clip (with handles ) from timeline for VFX dep ?
jeremie galan
on Dec 13, 2014 at 1:17:37 pm
Fairly new to Avid and wondering what was the best way to send out/export one of my edited clip ( with correct tc, edit points ( with added handles ) to my vfx artist ? The project is dnxHD185 so no need to go back to the original file.
And second, what is the same workflow if my clip is in dnx36 and i need to reference to the original file, but again with the correct in/out points, handles etc )
Best regards
Jeremie.
Michael Phillips
Re: Export single clip (with handles ) from timeline for VFX dep ?
on Dec 13, 2014 at 7:26:48 pm
If you need to send media (essence), drag the events into their own timeline (copy/paste, or subsequence). Then with that new timeline of just the events of VFX, you can consolidate the media with handles to a target drive then send to your artist.
If metadaa only, then for the same sequence of VFX events created in prior process, use "decompose" to create a new set of clips with defined handles, drag those clips to a timeline, then generate an EDL or AAF depending on what their system supports which will have the info they need to go back to the original sources.
Michael
jeremie galan
on Dec 13, 2014 at 10:03:30 pm
Great thank you a lot !
