AVID MC 8.0 Newbie - Move all audio track A2 contents to A1?
Ashley Edwards
on Dec 7, 2014 at 3:27:49 pm
Hi guys, very new to AVID 8.0, but loving the software.
Probably a very simple taskā€¦ but how do I move an audio track of multiple audio clips to a different audio track?
I'd like to move all clips from A2 to A1. If I select all the clips and then use the red arrow tool to move them, it only moves the clip on which i click?
Thanks peeps :)
Glenn Sakatch
Re: AVID MC 8.0 Newbie - Move all audio track A2 contents to A1?
on Dec 7, 2014 at 5:50:23 pm
You should be able to draw a box around all the clips and lift them all at once.
Another way would be to mark an in and out on the section, Ctrl C the section, and then in your source window drop down call up the clipboard contents. This will load what you just copied to the source window. use that as a source and edit it to the audio track you want.
Glenn
John Pale
on Dec 8, 2014 at 3:18:42 am
Another way...
Put in/out around the whole track. On a Mac press Cmd-X to cut, then target A1 then hit Cmd-V (paste).
On PC, substitue Ctl for Cmd.
Pat Horridge
on Dec 9, 2014 at 8:03:07 am
Or drag the sequence to the source monitor. Make a new sequence. Patch the tracks as required. A2 to A1 and video if needed and then edit the whole thing across.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Ashley Edwards
on Dec 9, 2014 at 10:56:51 pm
Thanks for all the responses guys. All methods seem to work. Many thanks!!
