768X1024 sequence
Olivier Prudhomme
768X1024 sequence
on Nov 26, 2014 at 1:14:42 am
I have 1920 x 1080 footage of a talking head that I need to export so it can viewed on a vertical screen of 768 x 1024 (don't ask me why :-) and yes it should have been shot differently)
Any ideas?
I was thinking to first rotate the image so at least it's now 1080 x 1920 but it's not really helping...
Thx in advance!
Michael Phillips
Re: 768X1024 sequence
on Nov 26, 2014 at 1:43:29 am
Do you need to recompose the shot, or just take it as it is and have the monitor display as portrait?
That aspect ratio is basically a flipped 4:3 monitor (3:4). So is there a crop involved as well as scaling down?
Michael
Olivier Prudhomme
on Nov 26, 2014 at 2:06:01 am
The talking head is dead center but I would have to scale it down a bit so there is a little side head room...
AS far as cropping Only the left and right
Michael Phillips
on Nov 26, 2014 at 2:11:18 am
I would do it in After Effects if you have that available.
Michael
Olivier Prudhomme
on Nov 26, 2014 at 2:13:49 am
yeah i thought of that but no AE in the post house...
Thinking of bringing it in FCP...
Shane Ross
on Nov 26, 2014 at 3:22:29 am
FCP would have the same issues as Avid. Both of them aren't designed for this resolution. They are designed for broadcast TV work. Well, FCP 7 and earlier is.
You need to use an App that was designed to deal with this...like After Effects or even Premiere Pro. DOn't have it? Well, now you have an excuse to get it. Because you have video that you need edited, and the apps at hand aren't designed to deal with it.
Shane
Little Frog Post
Olivier Prudhomme
on Nov 26, 2014 at 6:07:31 am
great info, thanks Shane.
And BTW I am the guy you helped his career starting! You got me a job as a lead assistant editor at the Incubator in 2008!!!
This was the job which got my career started. I have been editing promos for TV networks for the last 5 years now and part thanks to you!
So thank you for still being around and help!
People... this man ROCKS!!!
John Pale
on Nov 26, 2014 at 1:54:22 pm
Don't forget, you can rent Adobe Creative Cloud month to month. You get After Effects and Premiere Pro (and everything else). Not a huge investment to get the right tools for the job.
Shane Ross
on Nov 26, 2014 at 5:56:12 pm
Hey Oliver! Good to hear from you. Glad to know you are doing well.
So cool hearing from you. THis is neat.
Shane
Little Frog Post
Olivier Prudhomme
on Nov 26, 2014 at 7:04:04 pm
Thanks all.
I was able to get AE in another bay so pb solved!
Eric Santiago
on Dec 4, 2014 at 3:24:29 pm
I've always wondered if there was a free/cheap utility that would rotate video clips.
In the Digital Signage world, we have our preComps set to both Portrait and Landscape but the schedule system software we use allows 90 degree rotations in any direction.
Michael Phillips
on Dec 4, 2014 at 3:36:02 pm
If the file format is .mov, I use QuickTime settings to rotate display for each file.
Michael
