stabilize footage that is reformatted as pillarbox
John Hill
on Nov 6, 2014 at 6:19:09 pm
I have a 4x3 clip in a 16x9 project that is reformatted as pillarbox.
When I apply stabilize the image no longer has the pillarbox and the image exceeds the pillarbox masking.
I've applied a 4:3 sidebar but it moves along with the stabilizer effect even if I place it before the stabilizer effect.
Any suggestions?
thanks!!
Michael Hancock
Re: stabilize footage that is reformatted as pillarbox
on Nov 6, 2014 at 6:58:46 pm
Apply the 4:3 sidebar to an empty track above this clip (you may need to do an Add Edit to the filler so the effect doesn't go on the entire empty track). If you do that the 4:3 won't be affected by the stabilization.
Michael Hancock
Editor
John Hill
on Nov 6, 2014 at 7:23:24 pm
Thanks, Michael...I should have said that I tried that...not sure why it's not working though...even though it's on a track above it is still moving as per stabilizer instructions...strange...
John Hill
on Nov 6, 2014 at 8:10:12 pm
I made the letterbox I added to the top track green to show that for some reason the letterbox effect has also squeezed the image and added the black border.
