Clip organization in Bin & Sequence...
Dustin Schmitt
on Nov 3, 2014 at 10:57:44 pm
Hello,
THE GOAL: I want to select all clips in a bin and add them into a time line trusting that all clips have the play head at the top of each clip so I know that all of the media on the time line reflects 'ALL' of the media in the bin.
I know that if I 'select all' of the clips in the bin and hit the 'clear IN/OUT' key the clips 'IN/OUT' points will be removed, but I would like to know how to 'select all' clips and set the play head at the TOP of all of the clips. Is this possible?
Glen Montgomery
Re: Clip organization in Bin & Sequence...
on Nov 3, 2014 at 11:24:21 pm
You won't need to set the playhead. Just clear all in/out, select all your clips in the bin, and hit the insert or overwrite key; they will all then be added to the open sequence.
Editor / Santa Monica, CA
http://coldpost.tv/
Michael Phillips
on Nov 4, 2014 at 12:50:17 am
Or...
Select all clips in the bin and holding down the option (OSX) or ALT (Win) selecting AutoSequence from the bin menu. It will create a sequence of the entire sources in ascending timecode order.
Michael
Scott Cole
on Nov 4, 2014 at 11:32:53 am
If you are in the SCRIPT View mode, (mode with both thumbnails arranged vertically, and a large text box for each clip in the bin) first hit Ctrl-A to select all. Then you can hit HOME, to put the play head at the top of each clip. You can than MARK IN (using the I key), or MARK OUT ((O key). You can also navigate through all the selected clips using the 1, 2, 3, and 4 buttons (Move forward and backwards 1 and 10 frames). I have a text bin view with "Name," "IN," "OUT," and "In-Out" columns which I pre-select before entering the SCRIPT View mode.
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
