Re-adjusting Color Correction on clip - media composer
Nancy L. Sutton Smith
on Oct 26, 2014 at 2:01:10 pm
I haven't figured out how to select the color correction on a clip to re-adjust. Sometimes I will open color correction and I see the previous adjustments, other times I think I have it selected and CC applies a filler. How do I select existing color correction FX on a clip and change it?
Northeast Community College
Mass Media/Journalism/Post Production Instructor
Sutton Bay Media Company
Michael Phillips
Re: Re-adjusting Color Correction on clip - media composer
on Oct 26, 2014 at 3:11:54 pm
Make sure you are only monitoring the track on which the clip lives. If you monitor anything above that, the color correction will get applied to that clip or filler if that is what is active at that point in the timeline.
Michael
Shane Ross
on Oct 27, 2014 at 4:13:36 pm
Go into the WINDOW menu, and choose WORKSPACES>COLOR CORRECTION. If a color correction effect was added to a clip, this is the only way to make adjustments to it. Need to be in a Color Correction window layout.
Shane
Little Frog Post
