Avid Offline Editing Process
Fred van Stry
on Oct 13, 2014 at 6:45:27 pm
I'm setting up an Avid project and am transcoding files for the first time in order to edit with lower resolution clips.
My question is: Should I sync up the clips with the audio prior to the transcode or after it?
My logic says I should do it before, but I am not sure.
I've tried to find an answer to this online but failed to do so.
Thanks for your help.
Shane Ross
Re: Avid Offline Editing Process
on Oct 13, 2014 at 6:50:14 pm
Transcoding and organizing is done before you sync. Transcode...organize, sync...
Shane
Little Frog Post
Fred van Stry
on Oct 13, 2014 at 6:51:46 pm
Thanks a lot Shane.
