Match back to a Sequence
Steve Rogalinski
on Oct 9, 2014 at 4:08:19 am
How do I match back to a sequence rather than an individual clip? I use a selects reel that has effected footage and I don't want to match back to the original material.
Steve Rogalinski
Shane Ross
Re: Match back to a Sequence
on Oct 9, 2014 at 4:58:11 am
You can match back to clips, group clips, multicam clips. You can't match back to sequences. Sorry
Shane
Little Frog Post
James Patterson
on Oct 9, 2014 at 1:59:42 pm
If all of your 'effected' footage is in the same sequence one option would be match frame to the master clip, open up the selects sequence and then reverse match frame to find it on the line.
Not the most elegant solution but helpful if you have quite a large line of selects.
Best
Paddy
Daniel Frome
on Oct 9, 2014 at 2:00:29 pm
[Steve Rogalinski] "How do I match back to a sequence rather than an individual clip? I use a selects reel that has effected footage and I don't want to match back to the original material."
Load your selects reel into the source monitor, then use "reverse match frame" command.
