avid msp mxf plugin are not compatible with this editor version
Nadya Alves
on Sep 20, 2014 at 9:07:13 pm
Hi, I've just installed a trial version of Avid Composer 8.1.0 on my mac 10.9.4, and I have an issue, can anyone help me please?
1. I'm getting this message when the program is loading:
- Where can I find the Plug-in so I can uninstall this? searching in finder doesn't help.
- Should I download MXF OP1a Plug-in? (That's the only one I found that sounds similar to MSP MXF??
http://www.avid.com/US/products/Avid-Media-Access
2. Maybe this is related to the first problem, but when I'm starting to import a footage from Canon 5d Mark III to Avid after a few successfully imported files I'm getting a message that The file format 1234.MOV is not supported for import.
Would really appreciate your help!
David Collupy
Re: avid msp mxf plugin are not compatible with this editor version
on Jan 10, 2015 at 5:37:52 am
Ugh. I am having the same problem.
The solution is here:
http://community.avid.com/forums/p/124913/716366.aspx
And it's a pain in the arse to fix!
Nadya Alves
on Jan 10, 2015 at 9:04:41 pm
Hey David,
I've fixed the problem since then by calling AVID customer service.
I had only a trial version but they were able to help me and guided what I should do, there were several steps to fix the problem, including deleting several files, writing something on terminal and reinstalling the program, I won't remember the exact steps now unfortunately. I would definitely recommend you calling them.
David Collupy
on Jan 10, 2015 at 9:46:33 pm
Hey thanks for following up, Nadya. I pretty did the steps you mentioned, but nothing with terminal commands. Who knows - maybe Avid has addressed the weirdness of it all with the latest build. Everything *seems* to be ok now. But, if I experience any issues, I'll definitely be calling Avid to guide me through it!
