EDL Manager not opening EDL
Victor Vazquez
on Sep 12, 2014 at 3:27:06 am
Hello,
I'm trying to bring an Apple Color clip into AVID as an EDL and for some reason the EDL Manager is saying "The file is not valid and can't be opened." Have you ever run into this issue when working with EDL's and AVID? Do you know of any fixes?
Victor Vazquez
Victor Vazquez
http://www.victorvazquezeditor.com
Michael Phillips
Re: EDL Manager not opening EDL
on Sep 12, 2014 at 11:24:42 am
What EDL type did you export from Apple Color (did not know it exported EDLs), CMX? If so, which flavor of CMX? Does it have a .edl extension?
Michael
Victor Vazquez
on Sep 12, 2014 at 10:14:11 pm
It says: Avid 3400 EDL File. And it is an .edl extension.
Victor Vazquez
Victor Vazquez
on Sep 12, 2014 at 10:21:57 pm
I'm wondering how to import work from Color into AVID.
Victor
Victor Vazquez
Michael Phillips
on Sep 13, 2014 at 4:34:35 am
Are you rendering a timeline in Color as a single clip or a clip for every event? What are you rendering to codec wise?
Michael
John Pale
on Sep 13, 2014 at 1:56:42 pm
If you don't want to send out a single "flattened file", it's probably better to Send to FCP, then use Automatic Duck to get to Avid.
Honestly, Color has been discontinued for years. Probably better to start your transition to using Resolve on your next project, as there is a real workflow in place for that. Color never had a bulletproof workflow to go to anything else but FCP.
Victor Vazquez
on Sep 13, 2014 at 10:00:28 pm
Yeah, since Color is Apple as well I had a feeling it was more compatible with FCP and the two work nicely together. Resolve is definitely the way to go. Thanks.
Victor Vazquez
Victor Vazquez
on Sep 13, 2014 at 10:04:41 pm
I'm rendering as a single clip in Color and I think they render to ProRes. One work around I was able to do when rendering a single clip was go into the Color Documents -> Renders folder and get the file and drag it into the AVID project. I'm not sure if there are other ways to bring the rendered clips into AVID from Color. Thanks.
Victor Vazquez
Michael Phillips
on Sep 13, 2014 at 10:10:58 pm
You can render your clips to a folder and then AMA link to them using the QuickTime AMA plug-in from within Media Composer.
Michael
Victor Vazquez
on Sep 14, 2014 at 3:29:02 am
Thanks!!
Victor Vazquez
