Transcoding AVCHD footage in MC 6.5 audio problems
Robert Garry
on Sep 8, 2014 at 10:27:24 pm
Hey everyone,
Having a bit of an issue transcoding AVCHD footage. I have brought in the files via AMA and am attempting to transcode them. Several of the files worked perfectly however I am getting some audio issues on a few of the clips.
Basically the transcoded clip has all the video but the audio file cuts off about halfway through. When I check the AMA version of the troublesome clip I can see and hear audio throughout.
I'm transcoding to DnX145 and converting the audio to 48k. (I've tried not converting and the same thing happens.)
Again, I've got several clips that work just fine but a handful don't. Not sure if clip length is a concern since some of the problematic clips are under 2:00 while others are around 19:00.
I'm doing this all off of a USB drive (not by choice, trust me). Could that be part of the issue?
Any ideas on what could be causing this?
MC 6.5
osx 10.9.2
Thanks in advance!
Robert Garry
