Match frame Audio
Sarah Furie
Match frame Audio
on Sep 5, 2014 at 5:45:31 pm
Hello,
Is there any way to match frame audio from a sequence and then "find bin" like you can with video?
Thanks.
Michael Hancock
Re: Match frame Audio
on Sep 5, 2014 at 5:48:32 pm
Deselect all your video tracks in your sequence.
Select the audio track that has the clip you want to match frame, and hit Match Frame, then Find in Bin.
If it's not important that you load that clip into the source monitor, hit Alt/Option+Find in Bin from the sequence and it will go straight to the bin and select that clip. No need to matchframe if you just want to find it in a bin.
Michael Hancock
Editor
Scott Cole
on Sep 6, 2014 at 11:28:41 am
Better yet, just right click on the track indicator light (I'm pretty sure it's the record side indicator)and select "Match Frame." You don't have to turn off the other tracks.
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
