Blackmagic 4K Plugin?
David Jones
on Aug 29, 2014 at 1:23:25 am
Greetings,
I'm having issues using AMA with clips from the BMPC 4K. I'm wondering what plugin (if any) to use for 4K ProRes HQ clips. Any guidance would be great.
DCJ
Michael Phillips
Re: Blackmagic 4K Plugin?
on Aug 29, 2014 at 2:40:38 am
What are the problems? You don't say. Anything ProRes comes in via the QuickTime AMA plug-in. Just don't expect much in the way of performance. I find even 2K ProRes has a problem playing back. It's an AMA link transcode workflow for this one.
Michael
David Jones
on Aug 29, 2014 at 2:57:00 am
Sorry...the problem is that it won't link at all. A message box comes up and says I need to go to the Avid website and download the correct ANA plugin (which I thought was quicktime and already a part of Avid).
DCJ
Pat Horridge
on Aug 29, 2014 at 8:04:56 am
Can you play the QT file? Does it confirm the properties you expected?
Blackmagic don't make any plugins they force you through Resolve.
Prores should work via the native QT AMA plugin that comes with MC.
If you have MCs console open you when you attempt the link you may see more info.
Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
Free online Tutorials at VET digital media academy online http://vimeo.com/channels/752951
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
Michael Phillips
on Aug 29, 2014 at 11:50:31 am
I downloaded the 4K samples that were posted a month or so ago and have had no problems linking via the QuickTime AMA plug-in. There have been a version or two that had trouble transcoding ProRes in general which might be an issue. What version of MC are you using?
Michael
David Jones
on Aug 29, 2014 at 1:16:52 pm
I'm using version 8.0 (Trial Version) as we're moving from FCP 7 to ether Avid or PrPro CC. I've been learning both versions for the past couple of weeks and I'd like to go with MC.
Here's the code from the Console:
Forcing sample provider mode for video.
Appropriate QuickTime decompressor wasn't found!
[ Plugin Name = QuickTime Plug-In Avid Technology, Inc. Version = 1.3.2.6455 ] could not process /Volumes/TS_1_RED/DAY 3/A CAM/A004/Blackmagic Production Camera 4K_004_2014-08-09_1729_C0000.mov
GetCodecName | Failed GetCodecInfo with err: -8961
Most of the footage that we'll be using is going to be from the BMPC 4K but, if I can't get the AMA figured out we may have to go with PrP as I have no problems linking with it. And the clips do play back using QT. Maybe there's something else not set right or I'm doing something wrong but, the only message it gives me is "Unable to link to file or volume. You may need to download and install AMA plug-in from Avid AMA website".
DCJ
Michael Phillips
on Aug 29, 2014 at 1:41:00 pm
I would uninstall and download the 8.1 trial which is the current version. v8 did not offer anything of substance over 7.0.4 other than getting the new licensing in place. 8.1 was an actual release with features and bug fixes. I did not even deal with v8 til 8.1 came out.
Michael
David Jones
on Aug 30, 2014 at 2:17:17 am
Well, I uninstalled and reinstalled 8.1 and am having the same issue and getting the same error message as before, from the console:
------ AMA Link To File(s) ------
[ Plugin Name = QuickTime Plug-In Avid Technology, Inc. Version = 1.3.2.7205 ] could not process /Volumes/TS_1_RED/DAY 2/A CAM/A003/Blackmagic Production Camera 4K_004_2014-06-30_2014_C0000.mov
Is there anything else I could be doing wrong?
DCJ
Michael Phillips
on Aug 30, 2014 at 2:47:55 am
That is very strange. Are you in line with the compatability/support?
http://avid.force.com/pkb/articles/en_US/compatibility/en267087
David Jones
on Aug 30, 2014 at 3:28:40 am
I'm using a new Macbook Pro i7, 16Gb RAM, 500GB SSD and having no problems with anything else running on it.
The clips will link with no problem in Premiere Pro but I can't get them to, in MC. MC recognizes the drive and clips and will transcode them but not link them via AMA.
DCJ
Pat Horridge
on Aug 30, 2014 at 8:56:22 am
What version of QuickTime have you got installed?
Any chance you can upload the shortest clip you have somewhere so I can test it here?
Or send via high tail or similar.
Pat Horridge
VET
Glenn Sakatch
on Aug 30, 2014 at 3:35:06 pm
Is your ama set to auto detect? If so, try calling up the exact type of ama you want to bring in instead. I find autodetect works about half the time...depending on the source i'm ama'ing.
Glenn
Michael Phillips
on Aug 30, 2014 at 3:39:47 pm
That could be an issue, but I find that Autodetect will fall back on QuickTime AMA when stumped, and in this case, is the one to use. But I agree that directly selection QT AMA will at least eliminate that from the text matrix.
Michael
Pat Horridge
on Aug 30, 2014 at 4:24:05 pm
We know the QT AMA plugin is being called by the console feedback.
Pat Horridge
VET
David Jones
on Aug 30, 2014 at 10:48:48 pm
Yeah, the autodetect is selected when it's happening. I've tried selecting the AMA manually but it's not letting me; the ok button is grayed out. I'll try again this evening. QT seems to be correct and updated, too.
DCJ
Pat Horridge
on Aug 31, 2014 at 12:31:13 am
When you manually select the plugin you choose either qt folder or qt files. You then have to re navigate to either the root folder or a selection of files. Then ok.
Pat Horridge
VET
David Jones
on Sep 11, 2014 at 3:29:09 am
Argh!
After transferring the clips to a RAID drive (our master drive) and trying once again to AMA link, it still won't link and gives me this error message in the console:
[ Plugin Name = QuickTime Plug-In Avid Technology, Inc. Version = 1.3.2.7205 ] could not process /Volumes/CalDigit T3 12TB/toxic_state/test.mov
We're shooting 4K ProRes HQ with the Blackmagic Production Camera 4K. Is it possible AVID just won't AMA link this particular codec? Maybe it's too new? I'm still on the trial version; could that be a problem?
Very frustrated!
DCJ
Michael Phillips
on Sep 11, 2014 at 11:38:59 am
Is is using the new ProRes 4K codec that was announced a few months back? I don't have any sample media from that camera to check, so I can't verify what you are seeing. If you could send a small sample file to me at michael[at]24p[dot]com I will take a look. You can use a free service lik WeTransfer.com to send.
Michael
