Remove all color correction from a sequence
Frederic Lumiere
on Aug 27, 2014 at 10:12:29 pm
Is there a quick way to remove all color correction from a sequence without affecting other FX/Transitions?
Frederic Lumiere
Re: Remove all color correction from a sequence
on Aug 27, 2014 at 11:16:44 pm
ANSWER: In Effect mode, lasso clips w/ corrections, hit delete. But this will also delete other fx. Pls test Thanks @filmgeek Jeff Greenberg!
John Pale
on Aug 28, 2014 at 12:52:30 am
When in color correction mode, the remove effect button will only remove color corrections. You can select all and delete them
Frederic Lumiere
on Aug 28, 2014 at 2:12:51 am
When I'm in color correction mode somehow I'm not able to select all clips. When I remove effect, it deletes the last effect (even if it's not color correction)
John Pale
on Aug 29, 2014 at 3:17:13 am
Apologies. Don't know what I was thinking. You are right. It does not work.
Job ter Burg
on Aug 28, 2014 at 9:31:28 am
In the CC tool, right click and select "Remove Corrections".
Job ter Burg
on Aug 28, 2014 at 9:34:06 am
Come and think of it, that functionality may be part of the Symphony option.
