Audio Delay on QT Export MC8
Chad Smith
on Aug 18, 2014 at 10:04:22 pm
Using MC 8 to export a 4 ch quicktime to native DNxHD 175 and when I play the file back in QT Player 10.2 on my Mac running OSX 10.8.5 I hear an audio delay that gets worse as I play down the show.
However if I play the same file in FCP7, Soundtrack Pro,VLC, QT 7, or import the file back into Avid it plays fine. If I bring the file into Premiere Pro CC 2014 and look under the codec heading in the bin it says that the file is in an unsupported frame rate of 50.107fps and another file has a frame rate in PP of 49.32 fps. When I put the file in a sequence it plays fine.
Any clues on why QT 10 will not play the file properly?
