Vertical hold...
adam kurnitz
Vertical hold...
on Aug 6, 2014 at 2:11:11 pm
Hey,
I'm working with Media Composer 6.5 and I'm trying to achieve a vertical hold look. There doesnt seem to be an effect that achieves this look on its own. Is there some combination of effects I'd need to use?
Glenn Sakatch
Re: Vertical hold...
on Aug 6, 2014 at 3:31:34 pm
Boris fX has bad tv effect.
you could certainly play with two picture in picture effects stacked on top of each other animating, but a realistic animation might be difficult.
Glenn
Nick Griffin
on Aug 9, 2014 at 8:41:17 pm
Lots of effects packages have a "bad TV" filter. Boris Continuum Complete is the first that comes to mind AND I believe you can buy parts of the whole package individually. But, before you do you can check it out with their 14 day trial.
Also Artbeats used to have a series of bad TV loops, but I don't recall that any of them would simulate a vertical hold roll. You'd take thier looped footage into a top layer, apply AFX effects and experiment with different transfer modes to get the right amount of effect and underlying original image.
Matthew Skeris
on Aug 23, 2014 at 4:44:50 am
Here's the original...
https://landmarks.utexas.edu/projects/video/jonas
