Avid project format change
danielle wang
on Aug 5, 2014 at 8:06:34 pm
I accidentally created a project at 23.98/NTSC, but I meant to do 1080p/23.98. Is it sufficient to just switch the project in format? Or do I need to create a whole new project? Thanks!
Michael Phillips
Re: Avid project format change
on Aug 5, 2014 at 8:36:32 pm
For the most part you should be able to switch to 1080p and be good. There used to be a bug that starting in one format, then switching would prevent ALE files from importing. That may have been fixed, or ALE importing is not a need for you. If it is, just create a new project at the correct rate and resolution.
Michael
John Pale
on Aug 5, 2014 at 9:28:33 pm
Assuming you have not ingested any footage via import or tape capture, it's fine, except for the caveats Michael mentioned. If you have, that footage is now SD and won't simply switch to higher resolution. It will be upconverted SD. Avid is not resolution independent.
