Trim question
Lucien Newell
Trim question
on Aug 3, 2014 at 4:00:59 am
I've always wanted to do an overwrite trim over one frame before or after a clip, but Avid never lets me. How can I do this?
Glenn Sakatch
Re: Trim question
on Aug 3, 2014 at 3:27:00 pm
If it isn't letting you trim back 1 frame, my guess would be that our material has nothing left to trim with. There is no rule saying you can't trim back 1 frame. type -1 (or is it 1-?), or simply press the j key to trim backwards in real time.
As a side note, when I'm zoomed a bit further out on my timeline, and I notice that there is a flash edit like you have here, I usually just type -10. The trim point will always stop at the next edit, so you won't overwrite anything from the next previous shot. And if (while zoomed out) I mistook a 2 frame flash for a 1 frame flash, the -10 will take care of both frames.
Glenn
Luc Tarradelles
Re: Trim question
on Aug 3, 2014 at 8:41:12 pm
I had to go to Trim settings and set it to "go to transition".
I've been doing trims with J or L, but I like your technique - thanks.
