Can a non-drop clip be changed to drop frame on import?
Scott Davis
on Jul 31, 2014 at 6:32:27 pm
If I ingest a QT I am given; can it accidentally be changed to non-drop
Scott Davis
View Scott Davis's profile on LinkedIn
Michael Phillips
Re: Can a non-drop clip be changed to drop frame on import?
on Jul 31, 2014 at 6:51:00 pm
I don't know about accidentally as the import, or AMA link reads the timecode and gender from the file. If you need to change it, you can use "modify". May not work on AMA linked clips till you transcode.
Michael
Scott Davis
on Jul 31, 2014 at 7:01:37 pm
Thanks Michael, I didn't think that I could change it on import. Wanted to double check though.
Scott Davis
