3 TB LaCie P9230 Media drive only has 487.6 MB displayed
dan crouch
on Jul 18, 2014 at 8:55:39 pm
I have just bought a 3 TB LaCie P9230 drive to back up my media files on.
The problem is it only say's it has a capacity of 487.6 MB.
I have tried everything in disk utility to solve this but nothing has worked.
Has anyone here come across this?
Cheers,
Dan.
Michael Phillips
Re: 3 TB LaCie P9230 Media drive only has 487.6 MB displayed
on Jul 19, 2014 at 12:08:33 am
Are you seeing only one partition and the bigger one is not mounting?
Michael
Glenn Sakatch
on Jul 19, 2014 at 3:18:33 pm
I had this as well. As Michael said, it comes with two partitions.
Im on Windows, and just went into my disk management and deleted the old partition, and created a new simple volume for the drive, and it was all there.
I assumed the software the drive comes with would have done the same thing, but had already cleaned all that junk out before I noticed the partition issue.
Glenn
dan crouch
on Jul 21, 2014 at 10:48:46 pm
Thanks very much for your post's guys.
I was actually being a bit slow, I was trying to format it from disk utility and not the LaCie software! I have since used this and it works just fine.
Thanks again for advise.
Dan.
