How long it takes to export 100 minutes?
Avi Lev
on Jul 17, 2014 at 10:55:51 pm
I'm using MC v 5.0.4 on Mac OS x v 10.6.8
I would like to find outh how long does it take to export 1 hour and 40 minutes, Timeline with 3 Video tracks and 4 Audio tracks.
Project format : Type 1080/59,
Color Space: YCbR709, Raster Dimension: 1440x 1080
Into a QT Movie
Compression: H264
Quality: Best
Frame recording : yes
Encoding mode : multi-pass
Sound
Uncompressed / 48 kHz / 16bit / 2 channels
Thanks.
Shane Ross
Re: How long it takes to export 100 minutes?
on Jul 17, 2014 at 11:12:50 pm
Best way to find out is to do it. Because all of our answers may vary...depending on the machine we use to do the export. I'll wager it'll be done before someone who knows can chime in an answer...
Shane
Little Frog Post
Michael Phillips
on Jul 18, 2014 at 12:39:53 am
I would also not do it directly out of Media Composer. I would either export an QT refrence, or same as source, and encode in MPEG Streamclip, Adobe Media Encoder, Compressor, Resolve, Sorenson Squeeze, etc.
Michael
rainer lokken
on Jul 18, 2014 at 5:37:00 pm
Just curious, why wouldn't you do it out of MC?
Shane Ross
on Jul 18, 2014 at 6:00:08 pm
The quality out of MC isn't great. I only do review exports directly from MC. Everything else is done with Adobe Media Encoder or Squeeze.
Shane
Little Frog Post
John Pale
on Jul 19, 2014 at 7:01:20 pm
[Shane Ross] "The quality out of MC isn't great. I only do review exports directly from MC. Everything else is done with Adobe Media Encoder or Squeeze.
Gotta go along with Shane on this. Never directly export out of Avid if you want something that looks good. It uses a very old and clunky QuickTime export module. Fine for quick and dirty stuff, but not good for final delivery, unless you are exporting DNXHD.
This does not apply to using the new AMA based exporting for file based delivery (AS01, AS11). That stuff is fine, and does not use Quicktime at all.
Avi Lev
on Jul 19, 2014 at 10:15:18 pm
Thanks John
So how exactly can one output a scene from the MC to Adobe Media Encoder or Squeeze?
Adrian Beard
on Jul 22, 2014 at 6:03:26 pm
Sorry for the topic drift, but . . .
Shane, when would you choose Squeeze over Media Encoder? I've always used ME, but I have Squeeze as part of the Symphony bundle. I've never used it as ME has always managed to do what I've needed. Is it better at some export formats?
Just wondering if there are compelling arguments to finally learn it.
Cheers,
Adrian.
Shane Ross
on Jul 22, 2014 at 6:10:41 pm
I'd use Squeeze when I didn't have media encoder. Or when Squeeze had a preset that I need and ME doesn't. Happens on occasion.
Shane
Little Frog Post
Adrian Beard
on Jul 22, 2014 at 6:36:20 pm
Cheers, Shane.
Adrian.
Cheers, Adrian.
Avi Lev
on Jul 18, 2014 at 7:36:56 pm
Thanks Rainer
Out-, do you mean to device?
In my case I'm talking about Export not Output.
Export to QT file or any other video format.
